Hi Guys. First post. I have a rtv900w6. 1600hrs. Blows pressure side hydro filter. PM done at 1550hrs, used by the crew for 50 hrs and hydro filter split. We replaced the filter and it immediately blew out the gasket. I brought it in the shop and removed rear housing and hydro plate. Replaced housing gaskets and wear plates, because the wear plates were not perfect. Also installed a kubota yellow filter. Started it up and was bleeding the system (all 4 wheels off the ground), when I let the pedal return to neutral the oil filter gasket blew out. Took the filter off and reseated gasket. Removed charge pressure port and installed gauge. 500 psi at idle. I'm Lost. Any help will be appreciated. I inspected the 2 high pressure relief valves and they look ok. I inspected the charge relief valve and it looks ok too. I ordered 2 high pressure gauges to check the high pressure ports, but I won't get them until Wednesday. Thank you!!
