BX Axle Oil Dipstick
I checked the axle oil level on my BX2230 and noticed the dipstick is the same color as the oil. The only way to check the oil is to use your finger and I am somewhere between the normal lines.
I thought about painting it some contrasting color but wasn't sure if the UDT would dissolve the paint.
is there somewhere you can get a dipstick that will show the level a little easier?
Thanks
I have a similar problem with my SCAG ZTR mower. The only way I can tell the oil level is to use my finger on the dip stick which is not that accurate but I get an idea, so instead I get a very bright light and shine it on the dipstick.
