First time I've ever had an issue with my Kioti in the 7 years I've had it. Under a load, and only sometimes, the engine will stutter and rpm's will drop. Today I filled the fuel tank and noticed that the filter bowl was almost empty. I started it up and could see the fuel slowly running in...but not enough to fill the bowl. Should I pull the tank to see if the pick up is clogged? I can't see any pinched lines....
