was driving in the pasture this afternoon when my right front spring damper assembly broke. looks like the end of the shock came apart from the eye on the end.
Maby a defected weld? Generally you can see the condition of the weld old vs new break.was driving in the pasture this afternoon when my right front spring damper assembly broke. looks like the end of the shock came apart from the eye on the end.
Is there anything up in the shock that would prevent that shaft from rotating? I've never taken on apart or seen a diagram for one. But it sure seems like the only way that could have come unscrewed if the eye was intact. Do you have an angry ex-wife or girlfriend? I am just wondering if sabotage is another possibility. In all seriousness, glad you were not hurt and glad the equipment did not have additional damage.nothing broke!!!! the end just came unscrewed!!! a little locktite and i can re install.
thanks collie. i don't know yet about the other side but i purchased a new one for each side so now that it is home i plan on changing it out also.That's great news Aurthuritis !! How does the other one look ?
no ex wifes or enemy that i know of. the eye on the end is captive and can't rotate when it is installed in the rtv. the polish rod would have to rotated for some reason but i can't figure why???? the threads are perfect on the rod and on the eye and you would think at least the threads would be damaged???? i can't find a trace of thread locker either so maybe it just a mfg error??? but it made it almost 7000 miles. no girlfriend either.Is there anything up in the shock that would prevent that shaft from rotating? I've never taken on apart or seen a diagram for one. But it sure seems like the only way that could have come unscrewed if the eye was intact. Do you have an angry ex-wife or girlfriend? I am just wondering if sabotage is another possibility. In all seriousness, glad you were not hurt and glad the equipment did not have additional damage.
That is really strange that this happened. Maby over the last 7,000 miles every time you go into jounce/rebound the shaft tends to rotate ever so slightly? Especially if there is no locking device on the rod. You can't blame the Eye for this, probably, the shaft.no ex wifes or enemy that i know of. the eye on the end is captive and can't rotate when it is installed in the rtv. the polish rod would have to rotated for some reason but i can't figure why???? the threads are perfect on the rod and on the eye and you would think at least the threads would be damaged???? i can't find a trace of thread locker either so maybe it just a mfg error??? but it made it almost 7000 miles. no girlfriend either.
