I have the Retriever 1000 and have had nothing but problems so far?
Big "D"
Both rear axles went along with the front electric drive becoming unhooked leaving me a 5 mile walk to get the tractor to pull me back home?
The shifter will not go into park so I can start it unless it is on flat ground?
The shifter handle broke off about 3 inches from the knob?
The speedo is all over the map?
I also have the 4500lb winch with nylon rope and every time I use it, it gets tangled and impossible to pull out? (stick with the steel cable!)
The signal kit is not wired to the key so it can be on without you noticing and. kill your battery
They were very supportive? Of course never seen that before?
Still have to fix shifter, speedo and shift problem?
What is Lemon Law?
