The funny thing is that the differences I'm seeing... and the apparent accelerated wear/deterioration that I'd love to avoid... seem to relate more to the composition and strength/hardness of the rubber than to the ply rating, although it could be that the two go hand and hand for all I know.You can get heavy ply AGs. Got a pair of 8 ply on mine, max inflation is 60psi or something.
Might be that they are putting tyres on with a slightly lower load capacity to that of the front axle, so if you put much heavier tyres on you wont know its so overloaded.
Why can't R1s be made with the rating of R4s? With loaders and round bales, it would seem to reason today's tractors carry more weight on front. I have lost chunks of ribbing on the tires of my old Ford. Stumps do that sometimes. Are the Titans, as equipped on the Mahindras, lower in the quality department? On another note, my dealer gave me some pink valve stem caps. I painted them red to match the Big Red Beast.
Brandi,
I have 12 plys on the rear of my tractor. I believe you can get a heavier tire for the front too.
Ed,
I have 6 ply all around. When I need new tires, I will search out the higher rated tires.
I think your answer is pretty much on the mark. I see these smallish, cheap Chinese tractors coming over and being sold with aggies and I wonder how happy a homeowner can possibly be with that combo.
I would only dispute the notion that R4's will outlast a tractor. I am experiencing plenty of wear and deterioration with my Titans... plus some ugly punctures and one split. My front tires... not true R4's but skidsteer tires... are wearing noticeably and chunking. Part of the problem is that I work mobile and can't load the tires... meaning some occasional loss of traction and slippage. It also may indicate my lack of experience dealing with certain tough terrain (read: rocky) jobs, but I sure don't see these current Titan tires lasting forever given the residential client grading & excavation work I do.
The funny thing is that you look at an easy appearing job... like a patio prep job... and you think to yourself: "How many dang sharp rocks can there be under there"???For your purposes I suggest you look at the solid rubber tires designed for skid steers / forklifts and are designed to be better at " dealing with certain tough terrain (read: rocky) jobs," Your next best bet is a small dozer with steel tracks, lacking that expense I did have a set of rubber tracks for my Bobcat 754 w/12 plys but really didn't need nor like them and they were returned to my dealer!
I run Titans R4's 8 ply front and back w/o the problems that you describe, I'm unable to speak to other brands!
In the crazy world of the Dougster, my tire wear & deterioration problem doesn't even make the top ten... so I don't want anyone to think this is a crisis. As I said earlier, it is more of a curious nuisance issue that I'll need to keep in mind when the time does come to replace my tires. I don't think there is much I can do to slow the external deterioration. I address the punctures as they happen or as I find them. Someday when it makes sense, those tires will have to be patched from the inside and that one nasty split will have to be addressed.Dougster, if your main problem is stuff giving you punctures over here we have a product called nailguard. Its a liner made from braided kevlar and rubber I believe that goes inbetween the inside of the tyre and an inner tube.
Word is, they are the dogs...., well, you get the idea, very good in any case.
Maybe there is a similar product on the market in the USA.
