Kewl RTV add on's
GOLD Patron
In my search for a front rack for my RTV I found a few other items to add to my wish list and i thought some of you might be interested in some of them.
Feel free to add stuff you find tothis thread, please post a link with the item so we can get to it easily. If not sure how just ask. We are here to help.
I've needed one of these with my ATV and can use it with my RTV. and now it has Free shipping. :D
Impact Implements Universal Off-Road Utility Trailer
15 cubic feet hauling capacity
1500lb load capacity
Features quick release latch and tilt trailer bed for easy loading and unloading.
Pass-through 1" axle provides 12" ground clearance
18"x8" pneumatic, "tubed" tires for easy maneuverability over all types of terrain
Wheel bearings are sealed for easy maintenance and long life
High impact, polyethylene tub
$399 + free shipping. :D
http://www.4x4utv.com/product/impact-implements-universal-off-road-utility-trailer
Great Day Power Ride UTV Spare Tire Carrier
Power Ride UTV Spare Tire Carrier from Great Day Inc.,
Model # UVPR905STC / UVCCPR705STC
FITS MOST SMALL, MID-SIZE, FULL SIZE UTV
Please select your roll bar width ....
$191 + 19.95 shipping.
I know a lot of you have built your own stereo enclosure but now there is another option.
$429 for everything, free shipping to lower 48.
KUBOTA RTV 500 900 1140 STEREO SYSTEM CONSOLE WITH PIONEER DEH CD MP3 by TRACTOR TUNES™
Choose from Black or White Stereo Consoles
The RMT Roof Mount weather resistant ABS audio console housing is built tough using the latest injection molding technologies to provide a durable design.
THIS INNOVATIVE SOUND SYSTEM IS COMPATIBLE WITH YAMAHA RHINO, JOHN DEERE GATOR, POLARIS RANGER, POLARIS RZR, ARCTIC CAT PROWLER, KAWASAKI MULE, KUBOTA RTV900 and most UTV's with A HARD TOP ROOF!
Have a top but it's not a smooth surface? Add a foam insert (+$9) to work with ridged or nonconforming tops.
RMT Roof Mount ABS Mobile Audio Console Features
Includes a high quality AM/FM antenna. Built to OEM specifications for great reliability.
Marine waterproof retractable cover protects the DEH Pioneer CD Player.
WR85B Marine speakers are water, UV, and corrosion resistant and have a one piece molded grill for speaker protection and durability.
The DEH Pioneer is a 50watts x 4, 200 total watts mosfet* CD player with AM/FM tuner with 3 band equalizer .
MP3/WMA/MAV playback with volume and memory settings.
Connect your portable devices directly through the front AUX input.
Satellite Radio Ready for XM or Sirius through front AUX input.
Card Remote Control.
Detachable Face Security.
Overall dimensions: 18 in. L x 8.5 in. W x 5 in. H
Comes with a one year 100% manufacturers warranty.
* Not just 200 watts; this is MOSFET 200. Compared to conventional power supplies, the MOSFET amplification circuit is smaller and more efficient, and it delivers power with less distortion and absolutely zero on/off switching noise. Remember: more power doesn't only mean “louder". It also means that your music will be cleaner at higher volumes because you're not pushing the limits of the amplification circuit.
Please view the Installation Instructions at this link!
http://www.tractortunes.com/CMS/uploads/PDF/Install.pdf
UTV Stereo Kit / RMT Roof Mount Audio Console by Tractor Tunes™
Pioneer DEH CD / MP3 fits MOST UTV'S with HARD TOP
Free Shipping & Handling to lower 48 states
$40 Flat Rate Shipping to Canada
Please call or email for Alaska, Hawaii or international shipping quotes.
CONTACT US: Call 4x4 UTV Accessories or email www.4x4utv.com
link to stereo:
http://www.4x4utv.com/product/utv-stereo-console-kit-pioneer-cd-mp3-roof-mount-rmt-1-3
This could come in handy. Hopefully it is easy to remove when not needed.
Great Day UTV Rear Utility Multi Fit Rack
Part #: UVUR10MF
Fits: Multi-Fit - please see dimensions
Custom UTV Accessory Made in USA
Manufacturer: Great Day Inc
Aircraft grade aluminum.
Attaches securely to the UTV bed with included screws.
Maximum load bearing capacity of 100 lbs.
Expands 29" to 45" front to back - expands 41" to 59" side to side - up to 36" high.
Assembled weight varies from 30 lbs to 41 lbs depending on size of vehicle being installed on and whether the extension rack is being used.
http://www.4x4utv.com/product/great-day-utv-rear-utility-multi-fit-rack
How about a:
Quick Draw Overhead Gun Rack by Great Day Inc.
NOTE: Never transport loaded firearms in the Quick Draw Overhead Gun Rack. Some guns may extend out further then the top of your UTV depending on size of your firearm or how the gun mounts on rack.
Getting to your favorite hunting spot is the easy part, making sure you have room for all your gear can be tricky. Now you can have your firearms close at hand and keep them protected. With Great Day Inc.'s Quick Draw Overhead Gun Rack, carry up to two guns securely in the inside roof area of your UTV.
This is the easiest gun rack to install and takes literally seconds with no drilling or bolting required. Simply expand the telescoping rack to the desired length, fitting between the roll bars, tighten the bolts and you're on your way. Super soft gun grips with heavy duty Velcro provide easy access and secure transport. This gun rack will work with most UTV tops, however, it will not work on tops that prevent access to the rear top frame. Made in the U.S.A.
http://www.sidebysidestuff.com/quick-draw-overhead-gun-rack-by-great-day-inc--.html
Rocker Switches:
Are you looking for a way to control power to your accessories without having to put them in to the accessory position? Well look no further than these 12v 20amp rocker Switches available here at Side by Side Stuff.
These Rocker switches are a great option for controlling your aftermarket accessories they feature four pins and a colored back light to help you flip the switch you want when you want it! This is a universal fit switch so, some custom fitment may be needed to have for your application. If you are in the market for some aftermarket switches to control your accessories take a look no further!
$12.95 Free shipping
Features:
Rating: 12V 20A
Mounting Hole Size: 37.06 mm x 21.45 mm
4 Pins with colored back light
Universal fitting
Dashboard switch
Black hard surface
Does NOT include wiring harness
http://www.sidebysidestuff.com/12v-20a-rocker-switches-colored-led-back-light.html
Guys, I know some might find a better deal on some of this stuff out on the internet. If you do please share the info here much like I did. A description, price, picture and a link. Thanks!!!!! :tiphat:
My side mirrors move way to easily out of place, and I cannot get a good view of the load in the back. Maybe this would help:
Rear View Mirror for Kubota RTV 900
Price: $20.00 + $4.90 shipping
[ame]http://www.amazon.com/Rear-View-Mirror-Kubota-RTV/dp/B00IPMA9JC/ref=sr_1_2?ie=UTF8&qid=1463677365&sr=8-2&keywords=kubota+rtv+900+accessories[/ame]
Or this might be even better, a panoramic rear view mirror:
16.5" Extra Wide Panoramic Rear View Mirror Fits Kubota RTV 900
Price: $25.00 + $5.09 shipping
[ame]http://www.amazon.com/16-5-Extra-Panoramic-Mirror-Kubota/dp/B019NQPKGA/ref=sr_1_3?ie=UTF8&qid=1463677365&sr=8-3&keywords=kubota+rtv+900+accessories[/ame]
Does anyone have this item. Interesting. It would sure bling up the rtv cabin a little bit. :D
Sickspeed High Performance 52Mm Water Temperature Gauge Blue Q1 for Kubota RTV900
Price: $39.88 + $4.49 shipping
[ame]http://www.amazon.com/Sickspeed-Performance-Temperature-Kubota-RTV900/dp/B014VAM0YS/ref=sr_1_11?ie=UTF8&qid=1463677365&sr=8-11&keywords=kubota+rtv+900+accessories[/ame]
Doc, I have the Great Day Hood Rack. It is supposed to be a universal fit (comes with extra brackets for different applications), but I had to do some custom work to get it installed, but I like it. It does set high and block some of the close up view if I have anything very high in it. Currently I have removed it and do not have any photos. It is convenient to keep tools etc. and still have full use of the bed. I built a plywood box to fit in the rack to carry the tools. The way I fixed it, I can take out 4 bolts to remove it.
I don't remember for sure but, I think I got mine through Rural King. I'll see if I can look that up.
2014 RTV-X900
That was one thing I did not care for about the hood rack I saw. So open most small stuff would fall right through.
I have a different hood rack made specifically for the RTV but I can't get to my RTV or receipts for a couple days. Will post info then.
Good idea. Cheaper I'd guess. But how'd you get ahold of a school bus seat?
Is it easy to put in and out of the RTV bed?
Yes…I mounted it by drilling 4 holes in the floor of the bed to install 1”x1” angle 22” long. The school bus seat sits inside the angles and 4 holes were drilled in the vertical portions of the angles. Lynch-pins pass thru those holes and matching holes in the legs/stand of the seat. One minute to remove or install the seat.
The seat already had-installed seat belts for 3 persons.
I found a school-bus rental/charter company whom I did some business-with and they gave me two of these seats for the asking. (It’s common for school bus operators to remove a couple of rows to carry stored items…or wheel-chair-bound pax. It’s important you obtain seats which have complete (two) sets of end-legs…. as some bus seats attach to the wall of the bus on one end of the seat and only have one set of legs on the aisle-end. Otherwise you’ll have to build legs for it.
I can take pics if you need. (zoom-in on the left pic and you can see the mounts, pins, angle, etc.)
Looks handy, but just remember the people in that seat are going to get crushed in a rollover, and will experience much higher side to side forces than the driver (farther out from the pivot point) trying to throw them out the side of the vehicle in certain bumps. You can't judge the side to side forces from the driver seat, but they are going to move roughly twice as far (in the same fraction of a second, so more than twice the force) as driver does every time the vehicle bumps to the side. Children in that seat are likely to be leaning out the side at the wrong moment.
Of course if you're just puttering around like a hay ride, it won't matter, but if you're on trails like mine it could. Just something to be aware of.
