Hi, TWO GUNS.
Thank you for the input and your advise.
I know Honda's, in general, and BR's quality. I went to see it, but the dealer is not exactly good, and I read a lot of posts about it is underpowered, saying it's a tank, very good for flat terrain, and advising against it for hills.
Hi everybody.
I need to buy my first UTV very soon. I’m thinking seriously about RTV900 but I have several questions:
Is RTV good in high altitude?
Rod,
Here is a link to one of the threads discussing altitude.
http://nettractortalk.com/forums/showthread.php?t=10624
Now I been informed what "BR" means.
Wish I had a video and / or pictures to show. The Honda we use has more than enough power for some of these steep & slick hills we pulled. And sometimes there where over 3-5 hundred pounds in the back, with two grown men in the front ....
What more could a man ask for. The "BR" performed great !!!!!
........... two guns
Rod1,
I have talked today to a few diesel mechanics about the questions you had on the altitude with KUBOTA RTV.
Both said the same thing. It should be just fine being it is fuel injected.
And the system should adjust the fuel/air by itself without any problems.
They really went in depth with this conversation, long story short, but what they said, made all
sense.
I still would try before I buy >>>>
............... jamie ( two guns )
....!!! shooo..eeew.. I finally had to back on. (I was going after the forks that I had left at the other catch pen)Rod1,
This will start getting you the idea when I tell you what slick hills are .
I had a 2007 Kubota 1100 in colorado last fall and drove it to over 11,000 feet. 11,800 as I recall. The only problem was going up fire roads. Top speed up hill was maybe 8 MPH. Not necessarily a steep hill. This was at altitude. We were never under 9,500 feet. It would run 24 MPH on flat ground and 26 MPH down hill, where you could go that fast. How ever the 1100 RTV weighes a bit more than the 900. The factory sticker on the back of the cab, that also has the vin number on it shows a weight of 2903 lbs. That would be a dry weight without oil and fluids. Ready to go with add on's and people the weight would be well over 3000 lbs. At home,at about 600 feet above sea level, flat ground is about 27 MPH and up hill is around 22 MPH. As far as 4 wheeling in rocks and mud it was great. All you need are the proper tires for what you want to do. This forum has alot of info on tire choices. I think ( which can get me in trouble) That a turbo would help for driving up hill on smooth roads. getting a run at a steep muddy hill where you only have a short distance to accelrate to a faster speed where momentum is needed. Enclosed is a picture of us having a lunch break at about 10,600 ft altitude. This is in the old Camp Hail region of Colorado.
oldhat
Wish I could do a video of coming up my powerline. Where the front end lifts off the ground if you don't lean out over the hood with your heel on the diff lock. It is a far site steeper than that Ventrac is on. D5 cat was fun clearing it of trees. At $10 a foot I ran the straightest line I could for the electric co. to use. When the crew got out here they skipped the pole in the center of the hill that the engineer lady wanted and spanned it from top to bottom. It will climb about anything you can get traction on.
This 30% slopes are nothing to the RTV.
Been crowling up steeper and very much longer distances than whats
on these videos.
With a good set of aggressive tires, you will be surprised where the
RTV will go.
Wish I had a video of both RTV & Big Red running up and down the hills
in Mississippi. Let me add, the hills in the winter is usally wet, slick !!!
Before a gentleman purchased some aggressive tires for his new RTV. He was told
it's best not to go down this specific hill. He Didn't listen.
He had the OEM all terrain tires that come on a Camo model RTV. ( Them tires will get you in a bind )
He could not make it up the hill !!!! Backed up to him, tied up with chain, Pull not only myself, but his machine also up that slick, 30 - 35 % grade
hill. And it's a very long hill ...
He was just a spinning, I NEVER spun a tire. I am Running 589's on
that RTV .....
He went the next day and purchased some aggressive tires !!!!
Tires are the main thing. It's not all the machine !!!! You just need a
machine that will turn them over without loosing power ......
oldhat
..... I looked at the hour meter and it was just over 10 hours, can't be plugged up I thought. Cliff
