Life expectancy of the Kubota 3 cyl engine
Soo change the oil & filter every 50hrs ????
Change your FIRST Oil & Oil Filters at 50 hrs.
Change your FIRST Transmission Fluid & Filters at 50 hrs.
THEN >>>>
Engine Oil & Filter Change Again Every 100 hrs.
Transmission Fluid & Filters Every 200 hrs.
**** This Infomation Directly From Kubota Workshop Manual
Well thank you there mr. Two guns , I have a whopping 20hrs on her now Lol , I'll brt changing all the tranny is kinda rough the first time ? An also where's the fuel filter & how often on it ? Thanks
Fuel filter: Raise your Bed. Go to passenger side. Look toward fuel tank.
Follow the line coming from your engine to your fuel tank. It will be there.
Unless your machine in running ruff, or not starting proper. Or you can visually see your filter stopped up. Don't worry with it now. Always keep clean, good quality fuel going into your tank. If your getting fuel from a fuel can or a farm tank. I would suggest in getting a Mr. Funnel, so your fuel will ALWAYS be clean entering your RTV tank ....
Then you might want to change your fuel filter around the 150 hr mark.
If your machine starts getting weak feeling, feeling sluggish. That would be the firt thing I would change. I keep a extra in under my hood, in my goodie box at all times. It sits right beside the extra rifle cartridges....
........ two guns
