I never walk away from anything anymore.
Make sure the customer NEVER finds that out!
Ha!!!Make sure the customer NEVER finds that out!![]()
I guess you are right about that Mith! Last year, I tended to be very cautious and selective in taking on jobs and clients. I starved. This coming year, it will be a "no holds barred" battle against the competition, the elements, the physical risks and doubts in my mind over the wisdom of certain dubious opportunities!
My tub grinder guy is in Rhode Island near the Connecticut line. His prices are very reasonable (compared to here in MA) but the ride down there takes forever. It is all slow, congested back roads and in the wrong direction from where these potential clients are located.Doug, how far is it to the border from you?
Does the adjacent state have more liberal burn rules? (I can't believe I'm asking for a state more liberal than Mass) Maybe you can find someone there to dispose of it or burn it for you.
Jim
... which, of course, is exactly what a tub grinder does!I guess I've started you going in circles.
Dougster![]()
So far, in every town I've sought permission, I was told I could not outright bury stumps. I can grind and I can loosen and cut-down/push over in place, but I cannot remove it from the ground and rebury it elsewhere on the property.I put all my stumps out back out of the way to die off on their own. You can bury them as long as they are not in a wetlands area. Heaven forbid that you disturb land near a wetland. The frogs and salamanders may not like it and they will file a complaint against you.
More or less correct... but tell this to the property owners who don't want to pay for hauling and off-site disposal.Burning stumps and logs is illegal in Ma. as you mentioned. I think it even states a log over 3-4" as being illegal to burn.
Welcome to the People's Republic of Taxachusetts!No building debris can be burned either. I use my tractor as my fire putter outer. That bucket can move and stomp a fire out pretty quickly. I have never had a supply of water on hand when I burn. I am too far away from the house. I've also learned to never leave the wife in charge of a fire while I go off to burn another pile. She lit the whole backyard on fire once just by not paying attention. I did give her credit for burning all the elaves in our backyard. It is also illegal to burn leaves here.
I slept on this little problem, and It sounds like hauling it away in your dump trailer is the most profesional option.
For you wanabe rednecks like myself I will share two homegrown howtoos to deal with stumps still in the ground.
Cut the tree/stump as close as possible to the ground and then put your wood stove (hardwood) ash on it. It has a very low Ph (basic) and will rot the stump away in two years time.
BUt if two years is too long(and I am sure it is) , you could make your own "stump grinder" out of a 3 pt carry all. Put a steel deck on it and mount a brush hog gear box to the plate much as it would be on a brush hog. THen, instead of a mower blade weld two circular steel plates (or more) together to build a beefed up rotating circle. Modify this steel circle to accept commercial stump grinder teeth (avaialble from Baileys etc)
an voila, your own redneck grinder.
NOw it aint as good as a commercial unit, but you could have a machine shop make you one for less than $1000 and if you scrounged around and did it yourself, much less.
To use it get it spinning in low range and slowly drive it back an forth over the stump lowering you 3pt a little with each pass.
Now that Im thinking Dougster, if you can rent a commercial stump grinder, you could use that to break up your "out of the ground" stumps also.
