MF 285 Steering Problem Question
weco100
I've got a MF 285 that the tie-rod end (on cylinder end) has separated & come off of the ball. Can a new tie-rod end be welded to the cylinder or do I have to replace the cylinder?
At least for now, the end on the piston shaft is OK...
Thanks
Welcome to net tractor talk weco! Sorry I don't have the answer to your issue but I wanted to welcome you just the same. Hopefully someone in the know will be along with an answer shortly.
