Given that the hour meter tends to read hours at pto speed .
Doc, What You are describing is a Hobbs type hour meter . It works on a clock work type mechanism .John,
I actually never thought of it that way. I thought the hour meter was a reading of how long the ignition switch was on, regardless of what rpm you were running at.
However, if it is the PTO type, and I don't run my PTO 1/2 the time I'm using the tractor, is my hour meter running at all?![]()
