Onfoot and his new RTV900 and snowblower!
Onfoot
As I have indicated in another thread, after doing a lot of research
into what would be the best machine to meet my needs here in the Yukon
bush, with almost 1.5 miles of narrow road to keep clear of snow and
lots of firewood to keep coming all year and the odd hunting excursion,
the RTV900 came to be the obvious choice--especially after working
through this forum. So I made the leap on a 2008 worksite utility
model that was sitting in the dealer's yard and got (for this neck of
the woods, at least) what I considered a quite good deal. Extras
include glass windshield, plastic roof, front and rear worklights, 3k
Warn winch, 72" Curtis plow with electric lift, and a 'winter package'
that includes two block heaters (one on the block and one under the oil
pan), a transmission heater, and a battery blanket. Oh yeah--they threw in the Kubota hat. :-)</p>
But the most interesting and I think unusual add-on is the
snowblower. It is a two-stage, 60" wide blower with its own 31hp
Vanguard (Briggs and Stratton) gas engine. It rides on its own
pneumatic caster wheels, pushed by a long tongue which runs under the
RTV and hitches to the trailer hitch. It is a bit hard to explain, but
you can check them out at:
http://www.jimsrepairjimstractors.com/utility-vehicle-snow-blower.htm.</p>
Setting it up was pretty straightforward, the only issue being
needing to add about 18" to the length of the tongue. It also has a
control box that mounts in the cab and from which you can control the
various functions of the blower, including a kill switch.</p>
So after doing the tinkering yesterday, I was able to put her to the
test today. It was lovely. This morning it was -5F. I plugged it in
for an hour and then it started up on the first turn of the key, eager
to get to work!</p>
This year we have had record snowfalls and there is just nowhere to
put the snow. But no need to worry with the snowblower--it just
motored through and sent the snow flying through the trees. The only
downer was going through two sheer bolts--someone had lost a 5/8" pin
on the road, apparently, and naturally the snowblower found it. Lesson
learned is to keep a bag of sheer bolts in the 'bota with wrenches. I
am going to love this machine! Up until now I had been dreading more
snow--but now I can't wait! Bring it on!</p>
I am also eager to get into the woods and see how the 'bota does with hauling firewood. But next week. </p>
One thing I will say is that the stock HDWS tires are marginal at
best in deep snow. They will be fine for my summer work, but either I
will need to put on chains or find a more suitable tire. I know
several have recommended the ATV tires, but they can be even worse on
icy conditions.</p>
So the final need is to come up with a name for her. Will let you
know after I get a better sense of her personality. Have posted a
photo below. Recommendations and advice welcome! (Hoping to add a set
of Tommy's boot guards when he is able to knock them out.)/cs/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.36.14/RTV900-and-Snowblower.jpg</p>
NIce review and setup!!!</p>
Since you're hauling a lot of firewood, you may want to consider a bed liner, especially if you're like me and "toss" the wood into the box.</p>
Not mentioned but worth considering unless you already do so is to have a communications method with someone that may be able to assist. Once you get used to the machine and its capabilities, it may not be necessary but if you should get stuck or something, I'd hate to have to walk that distance in those temps.</p>
Where's the SMV sign?</p>
Onfoot,</p>
You made a big leap. Mister, that is one nice looking machine. For I know the feeling you have,can remember that rush that we gotaround here. That is a million-dollar picture my friend. </p>
As I've said beforemany times, the more you run this machine, the better it gets !!! AND YES, THE KUBOTA HAT, LOOKS GREATALSO !!! </p>
Onfoot,when the time comes,just might want tolook into that slider back window. Sure keeps much cold air off the back side and neck. </p>
You have such a wonderful machine, it will serve you very, very well !!!! </p>
KEEPSMILING ,</p>
~~~~~~~~~ jamie ( TWO GUNS )</p>
Mr. Onfoot........PROUD for YOU, Bud............</p>
Looks like you are ready to rock and roll big time. </p>
As an exclusive wood stove burner here in N. Ga, despite having 2 heat pumps, am wondering how many cords you go through?..........Any hard woods up there?......We pretty much use oak and hickory as that is what is native here as we produce and used maybe 4 cords this winter.</p>
I am wondering how those worksite tires are gonna do once they get plugged up with snow.........Are tracks in your future?..........</p>
Anyway............PROUD FOR YOU and God Bless...........Dennis</p>
i'm on them right i figure by middle of next week and they should be done. you wanted the aluminum right? you need to get some mud on that thing the shine is blinding me.</p>
Thanks, Dennis! We heat with a combination of wood, solar tubes, and oil, all providing heat to an 850 gallon heat sink which, through a complicated set of heat exchange loops, provides heat to our in-floor radiant heating system and domestic hot water. (Have attached a pic of the heat sink with the lid removed--I also took the radiator off of the 6kw Kubota diesel genset and added another heat exchange loop to the heat sink--so when the genset is running it adds its heat to the system and, when it is not running, the system keeps the genset warm for starting in our very cold temps.) I should say that we live off grid, so have to manage power carefully. I have 4kw of photovoltaics plus a 2.5kw wind turbine and, when all else fails, the genset--my first Kubota. :-)</p>
We also have a woodstove in the house 'great room' plus one in the games room over the garage. Living off grid, I have tried to build a fair bit of redundancy into the system, as well as designing it to cope easily with temps as low as -76F (the absolute record cold ever recorded in the neighbourhood back in 1947, I think).</p>
So how much wood? I have not kept accurate track, but I think about 7 or 8 cords overall. Less if I burn more oil.... :-) We live on 20 acres and are totally surrounded by 1000's and 1000's of acres of forest, so no problem finding all the wood I need. In five years I have not needed to go further than about 500 yards from the house so far, just cleaning up the woods from bug kill and windfall. But no hardwoods at all. Mostly white spruce and lodgepole pine with some poplar. It would be so nice to have hickory and oak, but they seem not to like the cold temps! (Though I do have two apple trees that seem to have taken root on our south facing hillside--hybrids from northern Manitoba.)</p>
More info than you asked for, but I am proud of the system and immensly grateful to the Lord for the priviledge of living in such a beautiful and wild place.</p>
Blessings to you also!/cs/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.36.14/Heat-Sink.jpg</p>
Thanks, Tommy! Yep...aluminum was my preference. As for mud, it will be mid to late April before there is any mud thawed out, but no problem losing the shine once the thaw comes! (The first observation made by my cousin visiting from CA Bay Area, where 4x4's never leave the asphalt, was how very dirty all the vehicles are in this neck of the woods. I told him that we actually need the SUVs we drive.)</p>
back in my sandblasting and painting days whenwe used to have to climb down into the tanks on the boats and blast them we had our little airconditioners on our hoods they would do ok in the fall and spring but in middle summer them tanks would get up to 120 degreeseasy in the day so we took our air line running to our hoods and coooled them up in a 55 gallon drum then we went to the ice machine and filled the drum with icebout 3/4 way up then put a little water. man we had some 50 degree and maybecooler air down in them holes. when i seen your setup it reminded me of that.</p>
Onfoot,</p>
I am impressed so much with yourheat sink ~~~~~ never seen one before....... I'm speechless for sure !!!</p>
</p>
~~~~~~~~~~~~ jamie</p>
</p>
Know whyTommy's interested in that copper , he's planning on makin' anotherwhiskey steel, >>>>>>>>>></p>
>>>>>>>>>>>>>>>>>></p>
Some ofdebest damn whiskey is made down in the LouisianaBayou >>>>>> yea man ~~~~</p>
There is certainly enough copper for more than one still! But up here I think the output would more likely end up being vodka, given that we grow potatoes... One thing for sure, I am glad I built the house before copper prices went through the roof. In the way of a bit of explanation, the heat sink serves two main purposes. The first is to allow me to burn my wood flat out, without needing to worry about dampening the fire to control temps. (Dampening the fire is a nuisance and a major cause of creosote building up in flues and risking chimney fires.) In effect I am simply transfering the btu's from the wood to the heat sink, where it is stored until needed for heating purposes. So, say, 4 hours of burning wood results in 12-18 hours of effective heat for the house, for example. The second purpose is to absorb the heat produced from my solar thermal array (photo below). Even now, with daytime temps in the range of 0 to 10F, if it is sunny, the solar array is producing all the heat needed for the house and garage. As you can probably guess, I love the challenges of living off grid and figuring out how to manage without needing to burn oil! Now if I could only figure out how to manage without needing to burn $$$... :-)</p>
/cs/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.36.14/PICT0075.jpg</p>
Onfoot,</p>
Amazing, truly amazing my friend !!!!</p>
Your a very lucky man, God has been good to you !!!
</p>
~~~~~~~~~ Two Guns >>>>>>>>></p>
That is a great looking rig Onfoot. Or should I say rigs so to include your great off the grid system. Just think if more folks would do this.Those solar panels ... Is that all of them or are there others.? If that's it, they are very efficient. In jr high school, I built a model of a solar house for the science fair using a "panel " painted black" that circulated water to a container in the basement (tomato juice can) surrounded by rocks to hold the heat. It worked pretty good for a kid with dreams. Seeing yours would put a spark in a lot of people. I bet that "Mother Earth " magazine would publish it. Anyway GREAT JOB!! Bordercollie</p>
Thanks, Bordercollie! (And also to Two Guns--I indeed count myself richly blessed!). To answer Bordercollie's question, those are all the thermal solar racks I have--a total of 88 'evacuated' (i.e., vacuum) collector tubes. You can read about them at: http://www.apricus.com/html/evacuated_tubes.htm. They are extremely efficient--on a sunny day when it was just short of -40F outside, they were generating 140F and adding that heat to the heat sink. Problem in the winter is simply that we do not have long enough days--only 4.5 hours between sunrise and sunset on 21 December. But now that the days are longer they are really making a difference. I only added them last summer, so this is my first winter with the collectors. But I am very pleased.</p>
Hello Onfoot</p>
</p>
Greetings from Seward, AK. Your snow blower looks like the way to go for those long stretches.</p>
I'm building off grid also. The shop is mostly done and the house should commence as soon as the snow leaves.</p>
I am installing 1845 watts of photovoltaic charging a1350 Ah bank@ 48 volts through an Outback mx60 and 2 VFX 3648's.</p>
I have part of my windmill tower up, 50ft,but am waiting for better weather to climb up there again. I have built my own turbine like the ones on otherpower. </p>
I had a bearing issue with my RTV but after tearing apart the trans it seems to be fine. </p>
I only have a plow on mine, I just bought one of those cheapies from Lowe's and made a mount for it, it works OK.</p>
I haver built my heat storage tank, 1000gal, and will be heating it with a Tarm boiler. I am curious about how your solar thermal panels work out. We have more clouds than you do but we are a bit more moderate temp wise.</p>
</p>
Later </p>
Wade</p>
Hello Wade! </p>
Sounds like we share some common interests. My system is
also 48v, with two MX60s for the photovotaics (two racks, each with
12x175w BP collectors). I have a 2100 Ah battery bank, a Proven 2.5 kW
wind turbine on an 88' tilt-up tower (photos below), 2 Outback FX2548
inverters and </p>
a 6kW Kubota diesel for when the sun don't shine and the
wind don't blow. And I also have a Tarm wood boiler and a Wiessman oil
boiler.</p>
As for the solar thermal set up, you could look up the solar
incidence for Seward and get a pretty good idea of what you would
need. My tube supplier is a guy in Ontario who I found really
helpful. Happy to send you contact details if you wish. Just email me
at barrett-at-onfoot.net. This will be my first full year, but it is
now giving all the daytime heat we need when the sun is shining. But
the end of the month I am hopeful that it will provide enough to see us
throught the nights as well. (Currently need to fire up the Tarm by
about 6pm to make sure we have heat through the night when the temp
dips and the demand goes up.)</p>
If you are passing by on the Alaskan Highway, you should drop by and have a look. Love to hear more about your set up, too.</p>
With respect to my RTV and plowing, there is just nowhere to put the snow once we have any amount down. And my 'driveway' is about a mile and half long--winding and narrow. With this winter's heavy snowfalls, I could plow for a week and still not have the road wide enough to keep from being pulled into the ditches. So the blower is wonderful!</p>
Onfoot (aka, Barrett)</p>
/cs/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.36.14/Electrics-Room.jpg</p>
/cs/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.36.14/SolarCell-Rack.jpg</p>
/cs/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.36.14/BWH-with-Turbine.jpg</p>
/cs/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.36.14/TurbineSunset.jpg</p>
Wade--forgot to mention that the electrical system powers two houses--ours and our son's. Otherwise a bit of overkill, probably.</p>
