un-pump
I copied this GIF picture from Northern Tools. It looks like what this pump probably was. As I understand it, that entire shroud normally contains water and it's purpose is for self priming. I now suspect that when it broke not only did that shroud terminate but the entire impeller chamber cracked all the way around near the outside radius. The part that I made covered the last stage of the impeller chamber and I had to shape it as it seemed right. I musta seemed it wrong! I've already shelved that basket and moved on to several new projects to screw up. I'm trying to get that Craftsman modified riding mower painted and back together. The modifications were major and lots of 'em, so final assembly is always a booger. I'm also working a lot of hours on my DC motor drive system for tractors. Today I took an old Makita 12V drill driver that had a destroyed chuck and junk batterys/charger and cut the front off just leaving a shaft stub to connect to. After cutting the pistol grip off (leaving the trigger) I could connect it to a 12V tractor battery. It seems to run well. I sprung it apart enough to inspect the gear box and was very impressed. It is very well geared down and should be able to operate a rear lift mechanism or some such. When I get my 6V tractor battery charged, and it stops hailing and raining for an hour, I will connect it with the 12V for another test of that 18V DC drive on Ol' Yeller. I'm still pretty confident the additional amp/hrs of power from those two batterys will enable that little DC motor to lift 200lbs net. without slowing down (as in the first test with the little drill battery). I can't imagine you or anyone else cares a rip about any of this, so I'll continue - it helps me focus project prioritys. I've been experimenting with small electric element water heaters. They range from 750watts to 1,800watts generally BUT I collared a spa heater that indicates 6 or 7,000 watts (240V) and if I can figure it out and fix it, I see the makins of a steam cleaner for my tractors and parts. I really want to get further into that one! Sometimes the connection between my projects and tractors gets pretty thin I suppose. If I catch flack I'll post about the manifold I made for my '36 Case model C or the "Gary66" method for timing my '37 Case RC, or my tricked-out 17.5hp (former) riding mower that now pulls big wheelies from a rolling start. I took the battery out to save my life after the last exhibition for pictures. Or about my interest in hydrostatic transaxles, such as my White with a BIG Wisconsin engine. Nuff
