Roper Belt Question
vannut72
I've got a 16hp Roper that blew out the cutting belt, can anyone explain how to remove the cutting deck and replace the belt? I'm mechanical but I just can't see this one
Thanks
Welcome to NTT vannut72!!!! :thumb:
I don't know the answer as I've never had a Roper but hopefully someone here will chime in with a tip or two.
Enjoy and post often. :D
Thanks
If this is basically the same as a Sears unit with the double pulley on the bottom of motor?...You don't have to take the deck off...you lace the belt back on and the last pulley that you roll the belt onto is the left hand pulley if you are looking at the tractor from the rear...It requires a bit of energy...:D
