RTV - Front Hydraulic Power Unit Question
606timm
I have been away for a week. I had my RTV-X100C sitting outside in sub-zero temperatures the entire time. It took a bit to get started this morning. After leaving it running for a bit, I engaged the PTO without issue. However, the hydraulics for the front broom (K-Connect) were very slow due to being so cold. I was able to move the brush up a little and then the front hydraulics failed to move at all. I let her warm up in my heated garage for a couple of hours and went back to try it again. When I push the buttons on the control handle I can hear the solenoid on the power unit click but nothing happens. It won't start the hydraulic power unit pump motor. Is there a fuse for this? Or is the motor seized? Or maybe just the solenoid is bad? Anyone have any fixes? Thank you.
I called my dealer today and they stopped out to take a look. It turns out it was the front power unit system 150-amp breaker that was blown. Yikes. It's just too dang cold!!!!
Thanks for follow up with the solution. Glad you got it going again. With Feb over half way gone it won't be cold to much longer (I hope).
