Just finished rebuilding the gear portion of the tranny on my x1100c from a failed bearing.
Put things back together and filled everything up with oil.
Started things up and there is a lot of aeration of the oil in the tank under the seat.
If I run in for a couple of minutes, turn it off and crack the hst filter I get some air bubbling out.
Have bled the air by loosening the filter multiple times but the oil is still aerated.
Any suggestions or is this normal after a full fluid empty and change? I've changed lots of hst filters and tank oil and can't say I've ever spent much time looking in the tank. I do know that oil with air in it does not lubricate well, so I don't want to run it before I get this figured.
