Hello everybody. Just found this forum and joined.
I had what I thought was the classic 4WD drive shaft clatter problem. It really sounded like a U joint to me. When I crawled under the RTV all of the U joints seemed to be tight, and there didn't seem to be any slack on the splines. But there did seem to be a lot of play within the front differential, although I don't know what is normal. What do you think?
Anyway, I unbolted the center bearing mount and pulled the entire shaft out.A test drive confirmed that the clatter was gone. I really can't afford to go to the dealer right now. My wife uses it everyday to get mail (a mile away) and do various light chores on the farm, but nothing that requires 4WD. So my main question is will it hurt anything to leave the drive shaft out and use it as a 2WD until I get the problem figured out and the money to fix it?
2007 RTV900 with 905 hours, filters and fluids all changed as per manual intervals.
Thanks in advance,
Larry
Thanks in advance,
Larry
