I have a 2010 RTV 900 which I use for fertilizing and liming food plots. Recently, I noticed a reduction in power (at 80 hours). Also, it wouild do only 18 MPH top end in high and when I purchesed it, it would do 25 MPH.
I took the spark arrestor out of the muffler and saw that it was plugged solid with soot. I did what was recommended by Spud Hauler and cut the screen off the tailpipe. I put the tailpipe back on the muffler and that solved the problem of the power. It was much better. Top speed became 28 MPH in high gear.
My only concern is that while traveling in the woods, a hunter stopped me and said there was a flame coming ouit of the tailpipe. Since I don't want to set the woods on fire, should I be concerned about this?
Also, I would like to eliminate the hex screws and use a case-hardened bolt to hold the tailpipe to the muffler. (I was having trouble and was stripping the hex heads. I finally got them out by heating the hex screws and then spraying them with water to cool them fast, and then putting vise grips on them. They then came right out.) Has anybody used bolts instead of hex screws for this purpose?
The machine's exhaust is definitely louder, but it does everything I want in two-wheel drive, low gear. I fertilize between 3-4 miles per hour, All three spreaders are ground-driven: 6-foot and 8-foot drop spreaders and a cone spreader.
Thanks.
Dennis
Thanks.
Dennis
