mikesells4u
I just replaced the load shaft o-rings and seals in my 2040 due to leaking oil. While I had the fluid out I checked the transmission sump screen and was not happy to find it clogged almost completely with junk. I would like to run the tractor for a couple hours and check the screen again to see if it picks up any more junk. My question is, do I need to drain that section of the transmission to check the sump screen? And if I do need to drain that side how much do I drain it? Completely?
