Video Says A Thousand Words.
It is just a little over the spec weight for the machine. :-) But in all fairness it is an impressive pull for this machine.
Can not see one of the other UTV's on the market capable of such a feat.
I could see other UTVs burning up or breaking a belt trying to pull that much weight. Honda Pioneer being gear drive would be the exception. Nicely done and good to know you can ask a lot from these machines and get it.
It is just a little over the spec weight for the machine. :) But in all fairness it is an impressive pull for this machine.
I'm surprised the RTV could tow that, and that the front wheels were still on the ground. That boat is a triple axle cruiser, 7 or 8k plus trailer weight. :wow:
hehehe I pulled a 300gl chemical trailer to a job about a mile up the street from my house the other day.
Pulled it just fine .. Musta been 3200 pounds ,. Love My X1100 !!
I was VERY Gentle and careful,,,,
Yes it is incredible what these machines can actually haul. One of its biggest plus's is the dynamic style braking when controlling a heavier load.
I have had a thousand pounds of weight in the box and coming down our driveway the machine just crawls with no brake effort required.
Impressive for sure. No idea what it weight but tracks put up more resistance than trailer wheels. I suspect that is not the owner of the RTV driving it. The way he tried for a running / moving start ....I feared he would break something.
I re
Wow and I was thinking about trying to use my Kubota to launch my 16-foot aluminum Walleye boat. I guess I have no worries now.
I regularly use my 1100C to put my Seadoo Sportster in the lake and remove it. I hook onto it and drag it out of the water backwards up over 18% grade to my garage. The machine dosn't miss a beat hauling close to 2000lbs like this.
For the record that is not me, my machine, or my video. It just happen to come across the 'recommended' videos and I thought of this thread. Although I have been known to pull some heavy loads with mine such as this woodland mills trailer. Sometimes filled with wood chips, dirt, gravel, and logs.
img_20200918_112355352_hdr-jpg.12740
I've towed a 20 ft boat with my ole 06 RTV 900. Did not launch it but moved it around the yard for mowing. 2500 to 3000 pounds.
