vehicle is a 2012 rtv1100
i need help! Let me tell you first,,i am only basic in my electric knowledge,,so if you start with any big technical language,,i won't get it. I can wire stuff if i have diagrams.
I ordered a book a month ago on my 1100,,but it has not come in yet for me to look at wire diagrams.
I have mounted a winch switch on the left end of the dash. I need a ground and power to this switch. I'm pretty sure I can find a ground,,but where should I splice in for power? Use "key on" power? Can i go to the ignition switch and splice in?
All the relays are hooked up under the hood, and my remote runs the winch properly. All I need is the cab switch to work,,and my install is complete.
2nd chore:
I have mounted a strobe light to the top rear of the cab on the center rubber rectangle. I looked at the fuse box for power for it, and found a fuse marked "spare". It is a 5 amp like the directions want. Do i need to remove the fuse box and add wire to the bottom of it to use this fuse? I can't see the bottom of the fuse box.
2nd chore:
