boxofrocks
First, my bx23 wouldn't start then i found that the Neg battery cable was loose and had split(not all the way. I jumperer around the cable and got the tractor started then I coldn' get it to shut off! I turned the key off, removed all the fuses andf connectors I could find and even pulled BOTH cables off the battery and the thing kept running. I called my dealer's mechanic and he had me pull the fuel pump connector then pinch the fuel line for about 10 minutes but neither attempt worked. He said I had a SERIOUS problem but didn't have any other answers. I thought about it for a bit and then removed the air filter and put a plastic cup over the air intake and it finally stalled out. Today I get to put everything back to the way it was and see if I can start it again(at least I know how to shut it down now) but I'm thoroughly confused as to why it wouldn't shut down thru normal methods. The batterty was low and I did have to jump start it to begin with. Did I screw something up, i.e. ignition switch,etc? thx
