x1100c oil leak out bottom of trans
dtreid
Trying to sort out an oil leak out the bottom of the hst on my x1100c
Appears to becoming from bottom plug #90 in parts diagram attached.
Replaced the o-ring on it and it still appears to be leaking. Not much, but a sweat shows up around the plug after just a couple of minutes of sitting.
Anyone else ever had this issue? Wondering about doubling up the o-ring?
Near as I can tell it was bad seals in the valve body where the bottom shaft runs throught. Oil was leaking past the seals and draining out the small drain hole in the bottom of the valve body.
You repaired it? Warranty repair?
