whatscookin
Had some time in the shop so I thought I would go after the brake fluid change on my 2006 RTV 900. Pulled the front wheels to find a cap that is held down by a bolt that a 10 mm wrench fits and under that are the bleeders. Then on both frame rails on the rear are the bleeders for the rear. The old fluid had turned yellow and the new fluid is clear. I sucked the old fluid out of the master cylinder first. Didn't take much time and two containers of new fluid is all it takes, and the wife pushing the pedal.
