It’s not just a Kubota thing. I own a JD4239 engine in a compactor and it had an optional starting-fluid injection system for arctic use which could be installed... BUT that system was specially-timed to inject the fluid only AFTER TDC so the piston was already on a downward stroke after compression. I own several different diesel machines and they ALL warn against using starting fluid/ether and the reasoning is the same.
Good luck with your pump problem. If you fix that issue you likely won’t need to continue risking your machine with ether.
