John Deere 4430
johndeere4230
I have a 4430 John Deere that i just purchased. The engine oil cooler is leaking pretty bad around the oil tubes where the tubes go into the angle piece bolted to the block. It appears to be 4 orings 2 on top and 2 on bottom of the tubes. Can I just take that angled piece off and pull tubes out or do I have to unbolt the cooler?
welcome to the forum JD4230. I'm glad you found us. :tiphat: :clap:
With a little luck one of our JD members will be along to offer their thoughts on this.
jdgreen
The cooler and angled piece both need to come off together. Then you can separate the tubes and replace orings.
dieseltech
Before removing the oil cooler, drain the coolant from the engine, remove the cooler. the gaskets are usually a little tough to scrape.
