kubmx5000dt
Have a problem can't figure out turn ignition on and left rear light comes on, I've unplugged the light switch but light still comes on any ideas what the problem is
No lights on with without ignition switch off and it is the back lights not fender lights,Hmmm.
Can you turn your lights on with the ignition in the OFF position? If so, do both rear lights come on?
For clarification, are you referring to the brake light built into the fender or the amber hazard light mounted on top of the fender?
no brake lights on this tractor just running lights and signal lights on rear it's 2003 serial # 51279 and like I said only happens on left sideOK.
On your tractor, are those back lights running lights only or do you have brake lights?
If you have brake lights and depress the brake pedal, do both sides of your brake lights come on and are equally as bright?
It may be a long shot but wondering if the switch for your brake lights has gone bad (it's stuck in the ON position) and your right side bulb is dead.
On this tractor no lights come on until the light switch is turned on that's why I can not figure out the left rear light comes on when key switch is turned on, I can turn on light switch and all lights are on, I'm about ready to just unplug the light that comes on when key is on lolIf these are running lights could the right one be burnt out and they both are supposed to be on whenever you turn the key on?
There's the Roadrunner bczoom, the bulb has two contacts problem still not fixed with tractor have new bulbs from Kubota on the way I haven't replaced any bulbs since I have had the tractor but it has 1157 bulbs in it so I don't know if the person I got it from had changed them and don't know what # bulb is suppose to be in it again thanks everyone
!968 I got it in 1978 383 engine 4speed transmissionAweosme Road Runner.69? Standard I'll assume. What engine you got in it? Very nice.
Thanks for updating what you've found so far. Truly unusual issues. Now at least others with the issue will have a clue on how to fix it.![]()
