D danzee New member Jan 25, 2021 #1 Key kill will not work no electric to shut off with key off. Headlight also stoped working
B bczoom Senior Member Staff member GOLD Patron Jan 25, 2021 #2 Welcome to the forum. Can you be a little more specific? Are you saying that you can't shut it down using the key? Have you checked all the fuses?
D danzee New member Jan 25, 2021 #3 I have checked all the fuses check good no power running to the shut-off solenoid with key and off position
B bczoom Senior Member Staff member GOLD Patron Jan 25, 2021 #4 Take a look at these things. Also, a bad battery may be in a possible culprit.
B bczoom Senior Member Staff member GOLD Patron Jan 26, 2021 #5 Any luck or updates? danzee said: I have checked all the fuses check good no power running to the shut-off solenoid with key and off position Click to expand... I'm "pretty" sure that the solenoid only gets power for a few seconds when the key is turned on and off.
