RTV 900 hydrostat pressure boost
reddog5527
Hello, Has anyone tried to step up the hydrostatic pressure? Seems I have enough engine, but too many times I had to shift to low (from mid range) to get going unloaded. Thanks
There is some adjustments, THAT SHOULD ONLY BE MADE FROM A
TRUE, BONIFIDE, KUBOTA MECHANIC. Not just one that calls himself one.
For there are many that do and are NOT that .
OK, From what I understand. There is some adjustments. What they are exactly, I don't know, BUT, there are some certain things that has to be just right for one to get the FULL amount of power.
We have a mechanic in Vicksburg, that took a look at mine, not that I was having any problems. He was at a friends place, checking hydro pressure on his. While he was there, he was kind enough to check mine out to make sure it was right. So I ran to my place, loaded up my RTV and brought it to him. He done some minor adustments and it give my 900 some more power altogether.
Again, I would ONLY advise to make sure you have a person that knows
what in the heck his is doing before he touches the adjustments and starts opening up the pressure valves ...........
.......... two guns
Mr. Guns,
Yea, your right. I do a lot of hydraulic repair (jack of all, master of none) and I thought it would be easy if I could get some direction.
Thanks for setting me straight.
RD
I was reading more today about adding turbo to a 900 or 1100. ...all it takes is money. :yum: I saw the turbo listed at 2500.
You might try finding out what size turbo fits the rtv an try searching s few scrap yards. They hsve been putting some turbos on them double drum units we buils sn they look to be good cross matchs for a turbo for the rtv..just look around before youdrop almost 3k at the bota dealer
