Seems to be a dog
Just saw this Doug. I dont see any feedback of you getting it straightened out and throwing a tool like the RTV away cause it doesnt work right is not a good thing..........Do you live close to Chattanooga or where?? It would be great to try to hook you up with the dealer there cause they have a tech there that is fantastic. Let me know if I can help you..............God bless....Dennis
Just saw this post and need help with my 2015 Kubota RTV 1100c transmission.
First off since your machine is a 2015 it could be an x1100c or just an 1100c. Huge differences in the two so please confirm your model?? Maybe a pic?
ee a new fresh fluid. No helpI bought the machine used in good condition. Prior owner did proper maintenance. I’ve hat it for 5 years. I’ve changed oil and filters. It started to have trouble moving especially uphill. Soon it hardly moved at all. I adjusted the fuel input to allow more fuel into system. No help. I drained hydraulic fluid and replaced the filter then put in new fluid. Still the same. Took to dealer and he adjusted pressure on tranny but that didn’t help. He said that there was silver metal on magnet drain plug and that I new transmission.
Ok thanks. Fresh fluids i assume filters and kubota fluids? Dealer adjusted pressures to what? Silver metal on what plug?" Makes a huge difference ". Silver metal on the gear case magnet is normal as long as it isn't chunky. The suction filter should have been cut open to see what the hst was like. Are you familiar with how this machine works?
