Side rails X1100 disappointed
Kanook
Maplenut....is that your sap gathering tank?......and if you ever tire of that plow I know of a needy foreign aid recipient (namely me) who would gladly take it off your hands...BTW...can almost smell that sap boiling.....what, another 6 weeks or so?
maplenut
That's one of many tanks Kanook. That leg tank fits like a glove in the kubota and I can't wait till see how it handles it . I'm gonna take rack that fits into the receiver hitch and re work the mount so it will be higher off the ground and strap down the gas pump that I use to pump out collection tanks. I usually tap around the 3rd week of February. Won't be long!
SpudHauler
When making my wooden version I stepped the front rails back just enough to clear.
thunderdome
Those are some great looking siderails Spudhauler. Also I really like the orange wheels better than the dark grey. :clap:
SpudHauler
Thunder,
Those are actually BX tractor rims (rear), not painted RTV wheel.
They are wider rims and caused the tires to rub on the front suspension parts, but give great floatation.
Was real hard getting the tires to fit because of the extra width.
thunderdome
Thanks Spudhauler, I like the bx wheels on your buggie. Looks really nice. My buggie is camo so I put some aftermarket wheels on it. The orange ones caught my eye. Have not seen any like that on one. Also great looking siderails on your buggie.:a1:
Old Man 1944
I made my light weight rails from 1"x 1 1/2" Oak. I coated them twice with outdoor clear sealer. I don't cut wood or throw heavy objects in the back (to old) so I removed the screen. I will be placing acorn nuts on the outside of each carriage bolt so you won't catch yourself.
Thanks for the idea from Spudhauler.
yeehaw48
If I can upload pics,here's my simple fix to the problem. simply remove bottom clamp and use a electrical conduit clamp to gain the needed room for side rails. You will have too place the boards on the other side of the standard. Also I used a thin piece of rubber to take the extra room at the clamp. Yes I know now you have to remove the clamps in order to clean the rear window. Please excuse the messy RTV it has been working here lately...good luck.
MFL
How do you like the Boss plow? Considering purchasing the exact unit for this winter in Michigan.
DwRam
Junior Member
I have the Boss V-Plow. It works great. I now wish for snow fall in Michigan, just so I can go out and push snow around.
71sschevelle
Side rails have come in handy on my daily corn picking trip.
Armyaviatr
here is how I made my front bulk head so it didn't interfere with the rear window screen. I used 11ga 1 inch square tubing and 11ga flat stock. The uprights are 16.5 inches and the flat stock is 6 inches wide. once welded together I sprayed it with U-Pol Raptor Black Urethane Spray-On Truck Bed Liner to match the bed.
  • 20220404_070832.mp4
    15.3 MB
Bota Fett
This is what I need to make! My firewood will never get stuck under the screen. Nice job Armyaviatr.
