If you're going to go with the concrete option, I'd suggest you see if there's any roto-mill available in your area. Roto-mill is ground up asphalt created when a machine strips off the top layer of a road or parking lot or whatever. You then take that, spread it where desired then pack it down. Being softer than concrete, it won't crack like concrete in the winters or from driving over it. It should be a lot cheaper than concrete as well. A friend told me a few weeks ago that he found a place around here that sells it for $150 per tri-axle dump truck load. You could fix that area then still have a huge pile of it for use in the future or at other problem locations.
Dennis, yes there is a sharp drop to the left, the way rock runs I suspect it is over to the right also. Rock is exposed where it is because of me driving over it and making ruts in that area.What is the angle of that slope? I like Californa's idea to cut a bypass a very few feet over. In the pics I cant tell the slope angle but to the right it looks like you could cut into that bank and go that way a bit. Does it drop off pretty steep on the left?
That would be the most fun way to take care of this issue. No doubt.Call rental yard and see what toys they have! Generally you rent on the weekend for one day rate.
Doc,
Monolithic means one pour. Not multiple pours with cold joints.
Go with the ramhoe and be done with it. Everything else is a bandaid.
Bring some by when you stop to visit. We'll have a BANG up time. LOLAbout two ounces of C4 could efficiently relocate that boulder. No one in Southeastern Ohio would even notice.![]()
Or realistically - hiring a blasting specialist might be reasonable if you want to go that way.
Preferable to transporting and working with explosives yourself, with no experience.
