Underpowered 3 point
chrisco911
Have an HD 2680 that the 3 point won't lift a 1500 lb bale. Why? Front end loader also seems underpowered as it won't lift the same bale unless the bypass is shut off to the 3 point. Any thoughts on what is the problem. Location is Eastern Oregon
This is what I pulled up on the tractor.​
Big difference between the two. Ours is the 97 HP. How can there be such a big difference between the information.
Massey Ferguson 2680 HD Tractor (2013)​
  1. Home
  2. Tractors
  3. Massey Ferguson
  4. Utility Tractors
  5. 2600 HD Series
  6. 2680 HD
massey ferguson 2680 hd specifications
PreviousNext
Manufacturer:Massey Ferguson
Price:51,963(USD)​
Series:2600 HD Series​
Model:2680 HD​
Equipment Type: Utility Tractors
Factory:Brazil​
Full Specifications​
VARIANTS​
2680HChigh-crop
NEBRASKA TRACTOR TEST 1978 2​
DescriptionDiesel 12-speed 4WD 6/24/2010 Link: Nebraska Tractor Test 1978 file PTO performance
Max power88.15hp / 65.7kW
Fuel use5.1gal/hour / 19.3l/hour
Power at rated engine speed86.06hp / 64.2kW
Power at rated PTO speed87.82hp / 65.5kW
MASSEY FERGUSON 2680 HD POWER​
Engine (gross)97hp / 72.3kW
PTO (claimed)83hp / 61.9kW
PTO (tested)88.15hp / 65.7kW
ENGINE DETAIL​
DescriptionPerkins 1104D-44T turbocharged diesel 4-cylinder liquid-cooled
Displacement269ci / 4.4L
Bore/Stroke4.134x5.00inches / 105x 127 mm
EmissionsTier III
Power (gross)97hp / 72.3kW
Pre-heatingglow plugs
Rated RPM2200
Starter volts12
MASSEY FERGUSON 2680 HD ENGINE​
DescriptionPerkins 4.4L 4-cyl diesel
Fuel tank26.5gal / 100.3L
I suspect it is the year in question. I did not add the HD.
This was for a 1980's version of the 2680.
The page was to big for me to copy this info in the original pic above. Sorry for the confusion ...
