Lug nut torque spec on 1140
Davooda
Looked all over the web and couldn't find specs on lug nut torque for my 1140 so I thought I would ask the experts! Need to remove wheels to install Peanut's stick stoppers and wanted to know proper torque setting for when I put them back on.
BTW - from the factory, some of the lug nuts were a serious BEAR to break loose. Needed a cheater and even then it was tough. Wonder why on earth they feel the need to drive them so darn hard with the impact wrench :whip:
Stick Stoppers
I didn't need to remove the wheel to install the stick stoppers, it probably would have been easier. Love em.
XTROOPER
:14_6_12:
80-90 lbs of torque oughta keep the wheels on. I installed Peanut's stick stoppers without removing the wheels. But if I had it to do over ... I'd remove the wheels.
Davooda,
My comment about "tight" was half in jest and probably not the answer you're looking for.
I looked in my 900 owners manual and it says:
(1) Torque wheel bolts to 75 to 90 N-m (7.6 to 9.2 kgf-m) (55.3 to 66.4 ft-lbs)
I'd think yours is the same unless otherwise noted in your owners manual.
Thanks all! I couldn't find the spec in my owners manual and my dealer isn't very good about returning phone calls.
Davooda
Tater driver,
That's the axle nut torque. Do you have the lug nut torque handy?
Tater driver,
I may be wrong, but I think tater drivers post states it. Think they are calling it
a " Rear Wheel Mounting Screw". Beside it gives the torque.
Like I said, I could be wrong >>>> Was wrong once before !!!! :wink:
I may be wrong, but I think tater drivers post states it. Think they are calling it a " Rear Wheel Mounting Screw". Beside it gives the torque.
I believe you're right after reading it closer. Who in the hell calls a lug nut a "Rear Wheel Mounting Screw"?!?!?!??!
If your asking me,
I would say Neutrals .....
With no doubt, you have met many in your walk of life also !!!
WHEEL BOLT TORQUE
Checking Wheel Screw Torque
CAUTION
• Never operate vehicle with a loose wheel screw.
• Any time screws are loosened, retighten to the specified
torque.
• Check all screw frequently and keep them tight.
1. Check wheel screws (1) regularly especially when new. If they
are loose, tighten them as follows.
W1059106
(1) Engine Oil Filter
Tightening torque Wheel mounting screw
75 to 90 N·m
7.6 to 9.2 kgf·m
55 to 66 lbf·ft
(1) Wheel Mounting Screw
KiSC issued
CAUTION
torque.
W1059106
75 to 90 N·m
7.6 to 9.2 kgf·m
55 to 66 lbf·ft
KiSC issued
................ ooooooooooooook :blob_blue:
Ok, one more time:
Propeller shaft slotted nut - commonly called AXLE NUT - 60 ft lbs torque would be good
Rear wheel mounting screw - commonly called WHEEL BOLTS or WHEEL NUTS or LUG NUTS - 110 ft lbs torque
Now the latest recommendation for the axle nut is 140 ft lbs as mentioned here in another post.
http://www.nettractortalk.com/forums/showthread.php?p=88386#post88386
#14 post
Enjoy
There you go,
Hope you typed it real slow. :pat:
Still easier to remember what bczoom said.
................. TIGHT !!!!
I'm just poking fun !!!!!
