Gotmyrtvmike
I have it jacked up, removed the HST lever, push the lever forward and turned the wheels forward while in gear to see if it would prime. Did not work. I will check those things when I get home. You guys are great. My son (12years old) and I are learning as we go.first check the easy stuff.... put it in neutral on a flat surface and see it it rolls easy? if it does then the brakes arent seized. in order for it to move in gear the hst speed lever must travel free and not spin on the shaft...not so common but check anyway. while your back there check the high pressure relief poppet to make sure it releases and resets properly. might lube it and cycle it a few times also. check these things and check back??? please? jack up the rear wheels off of the ground put in gear and throttle up to see if the rear wheels will spin without resistance??
