I was having the exact same issue as Gotmyrtvmike after replacing the diesel engine in my 2009 1140. When the rear end was jacked up the tires would spin in Low and Reverse for about 60 seconds while engine was cold but then after getting warm the HST would seemingly lose all pressure. Seemed like a high-pressure let-off issue but everything had been gone through to no avail. Finally caved and took it to local dealer and they very quickly realized I had swapped the order of the two external filters on the HST. Apparently these two filters have reverse "flow" functionality from each other and my "suction" filter wasn't able to suck...haha. Stupid me. Anyway, cheap fix. They slapped me on the wrist for having tweaked my servo and they went ahead and adjusted all of my throttle cables and servo adjustment...etc so its all dialed in. $300 in labor and problem solved. Check those two filters to make sure you have them in the correct order.
